Bigb55
What would be the best place to cut the rocker box for access to the rear cargo tub? I need to get in there to mount a backer plate for a rollbar in my '74?
I was thinking of cutting out a square where the inspection holes are on the rear plate. Just big enough to fit the backer plate and a ratchet. Then welding some flat iron across it for support.
Any better ideas? Would the bottom plate of the box be better? Only other option is welding the hoop legs to the floor.
I tried to access the rear cargo floor when doing my floor pan repair up front, but no go.
