I dont think anyone has the rear floor corners you want. You will have to fab something out of sheet steel.
At a minimum you will want front and rear floor sections. LMC/AMD/Tabco/Classic should all have that. All pretty much the same. The rear floor section will only cover the flat.
Once you cut the existing floors out, you will find out what else you need.
