Hossbaby50
3/4 ton status
I am running Amsoil in my Dodge Cummins. I drive 3-5K a month for work so changing my synthetic oil every month doesn't sound like alot of fun. I am currently going 15K on my oil changes. I use Amsoil 15w-40 diesel oil and this last time I used Fleetguard Stratopore filters that I changed every 5K. I am going to do an oil analysis on the oil when I change it to see what is going on with the oil and the motor.
My next oil change I am going to use Amsoil 15w-40 diesel oil with an Amsoil EAA filter and sample it every so often to see how the oil is.
Harley
Harley
) If you guys are happy running the lowend Wally World Synthetics then good for you. Just because an oil meets a certain spec doesn't mean it is as good as the other oils above it. Many of the better oils well exceed the spec sheets for the oil.
