Best way to get 6" lift?
The1980BEAST
Ft.Worth Tx
I was originally just going to get a 6" suspension lift from Skyjacker or something but I heard they dont have much flex?...WHat would be the best way to get 6" of lift front and back?
What I'm going to do...
4" TC E-Z rides in the front, with a zero rate. Shackle flip in the rear with 1 ton spring packs(burbs are heavy afterall) and a zero rate. Top it off with ORD body mounts and 1" body lift..
already got 3" body lift looking at gettign 6 more inches but I dont know what. Shackleflip? 52's in front ? If i put 52's in the front does that lift it any?
Heard this is supposed to give the full 6"s
Shackle flip in back will get you +4", so maybe that and 2" or 3" springs.
52"s in front generally net you about +4", though it also means crossover.
Simplest would just be all springs. Yes, the greater arch will mean a bit less flex, but are you doing crazy rockcrawling, trails, mud, what?
-- A
Mud and muddy trails, some trails are pretty steep and have some drops, I've gotten the rear passsenger tire off the ground on one hill
TC 6'' EZ rides in front, shackle flip/zero rate/ORD long super shackles in rear.
Thats what i have, now i am looking for another 2'',lol.
