best way to remove bondo?
A well ventilated area, preferably outdoors, lots of PPE, and an aggressive flap disk on an angle grinder. It's easy to see when you hit metal because sparks start flying.
I think a wire wheel on a grinder works better than the flap disk. Less cloggage. The heat one I'll have to try.
There is alot of bondo on the rear quarter. Some of it is from an old repair. I wonder if some is factory.
Small propane torch and a scraper. Just a little heat is all it takes. Faster, no dust.
That's the cleanest and fastest way to remove bondo.
I don't understand why anyone would want to try anything else.
