Best way to remove grease from axle
hi pinion
3/4 ton status
**PLUMBING THE WORLD**
There a little crustified,and need painting. Whats the best way to remove all the crap from em? Im getting ready to paint em up nice.Wire brush and simple green?:)
Oven cleaner.....I sand blasted mine. It took forever but they were clean enough to paint when I was done:)
I used to clean ovens for a appliance store when i was 15..........
Ive cleaned the piss out of alot of ovens for 5 bucks an hour, it burns the CRAP out of your skin, and face if you get it on you.
Gotta love that SODIUM HYDROXIDE , :crazy: but it works.
Ill try that in conjuntion with a wire wheel, i was thinking about a degreaser also, because its really caked on there good. Have any of you tried a degreaser? Other than oven cleaner? I hate that stuff. Ahh, the memories. :)
Oven cleaner is the strongest degreaser you're going to find. If you're worried, wear thick rubber gloves and goggles.
Im not worried. Its sounds like a big ass mess however.I figure EVERYTHING has to be off the axle in order to get paint to stick good to it. Mabey go with some primer, then paint, then sealer, to prevent rust later on. :)
me personally i use super clean and spray it on there and let it soak a pit and a pressure whasher you gotta be a little careful but was pretty much ready to be painted after i was done.
Hey dude! Hows it goin? I IM you the other day, but i accidently pressed the block button, and now i cant unblock it, so for the record, im not blocking your IMs on purpose. :grin: I have a 6000 PSI pressure washer that is actually used as a jetter to clean the plumbing lines for customers.......it has a pulsate feature also,,, it would scrape the paint off any car though LOL http://www.gorlitz.com/Images/Watter%20Jetter%20&%20Cable%20Machines/GO-1500A_REEL.jpg
I live in a residential area though, chances are itd spew crap as far as the eye can see. It has a seperate feed line to insert X chemicals, etc, mabey ill attemp that. Anywho, ive checked out your site and joined up, its pretty cool. Take care,Jacob :)
i sent you a pm the other day back but didnt get anything saying it was blocked if you want to get ahold of me you can pm me on my site or e-mail me at [email protected] is the pressure adjustable? and if you do it in the back yard shouldnt hav too much problems at least thats where i do mine but then my back yard looks like a junk yard......lol
Rick
Yes it is adjustable. I know the title sounds stupid :D ,,but ,,,one thing i dont have is time. The less time on this nasty pig the better.I figure i can save time by asking these questions. :) Try the IM again. ;)
pm sent but again i dont get on here much anymore so the best way to get ahold of me is throught krazyk5.com thanks again
Rick
Use the Greg72 method......
A case (or two) of Brakeleen and some old toothbrushes.
:cool1:
For the first iteration I use a putty knife. Next is Basin, Tub & Tile cleaner with a wire brush. Next is a wire wheel on a drill. Last is carburetor cleaner or brake cleaner with a toothbrush.
i just scrape all the heavy stuff off then spray some brakecleen or carb cleaner, then take my 2 inch diegrinder with one of those 3M stripping pads, works ok for me
I would try that pressure washer of yours first. I wire wheeled and degreased mine for a couple days and eventually couldn't get all the crap off the drum backing plates....I just painted over it. :D
load em on a trailer, take em to the local self spray wash at midnight. power wash to your heart's content, and you dont have to worry about cleaning the mess up. not that i've ever done that or anything. :rolleyes:
I could use a six pack!
I'd wash it for a six pack or two if I were closer!--I know a local contractor who does exactly that--hires drunks and crackheads for one day to paint a house or do roofing!(of course all our workers are experts Ma'mm:haha: :rotfl: :whistle: )---I have had good results sandblasting the rear axle housings,just use oven cleaner and pressure wash the heaviest goop off,tape up any spots you dont want sand getting into,and the sandblaster will take off the rest,leaving a perfectly clean surface ready for paint...:crazy:
