Bi-curious
Never seen that combo before, just one or the other. Don't the propane burners use a different fuel mixer, in place of a carb ?
I was doing some research about a while ago and this is what I came up with (on our older trucks, I have no idea how well they work on new FI'd ones)
You can run a truck three ways
Dedicated Gasoline--i think we all know how this works.
Dedicated propane--you can run a previously gassed motor with no ill effects although propane has a higher octane rating, therefore you must retard or advance (I forgot which) the timing to deter pinging. You replace the complete carb with basically an injector plate and the other typical propane setup. Now if you build a motor specifically for propane you can get more everything out of it as per the higher octane.
Gas/propane setup--you basically put an injector plate above the carb(with the typical propane stuff) and you run a switch to either run propane or gas. Now with the propane being a higher octane you basically set the timing to run decent with both, and that is typically why people say you loose power with a bi setup. now theoryetically (sp?) you can get out and change the timing everytime you change but who is really going to do that?
If I do it im going to run a dedicated propane
A lot of construction equipment such as boom lifts, scissor lifts, fork lifts etc run gas and propane options. I'm in this business and they seem to be very reliable.
Alot of the stuff at work is also a gas/propane. I never really looked at it though since we only run propane indoors.
i have been doing alot of calling around and reading on this subject for my 07 chevy
cost 2000 to 2500 for the set up plus a tank 400-1000 for my 6.0 motor
i am on the fence but my mind is really on this. i use 2 or sometimes almost 3 tanks a week. 1 tanks is 34 gallons, call it 70 gallons a week, thats 280 gallons a month on a very conservative guess. so more kike 300 gallons.
3000 cost to convert
propane is on avaerage 1.99 or less here, gas is right at or under 3.00
in 10 months I brake even. I suspect the price of fuel to lower and climb and continue to level off higher and higher.
some benifits,
propane less depended on issues oversea's?
I can store propane on my own property with little paper work
tax write off
drawbacks.. fill ups are not as easy to find, upfront cost, and mounting the tank.
