Big block guys
@Hoss7979 what do the numbers with the cam you listed show? http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=401&sb=2
When I honed it I just cleaned up some surface rust that formed while it was sitting with no Pistons or heads. I checked cylinder taper and roundness like Zim said and every cylinder was good.
That's the cam I run, I'll run the numbers when I get to work in the morning w/ your setup. Those numbers I posted before for ya were stock valves & pocket port job. Compression was set @ 9.5:1 as well
Also, I don't know anything about converters. Well, I know generally how they work, but nothing past that. The 268 cam says I can run a stock converter and I'd have to get a 2000 stall converter with the 270 cam hoss recommends.
Stock converters don't help you what so ever if you have any kinda aftermarket stuff done. I run a 2800 in mine right now.
Definitely talk to @Greg Ducato about the converter, you'd be better off getting one built for you instead of generic Summit type stuff.
If you call any converter manufacture there gonna ask you your complete setup & then tell you what stall & size you need.
You also have to realize "stock converter"......stock converter in what? There's a difference between a stock converter in a car & K5. My new cam I'm putting in recommends a 3k but due to my setup Comp Cams recommends a 3500
Depending on the numbers, I may just run the smaller 268h cam and stick with the stock converter that is in the truck right now. I'm still not sure how the 700r4 will hold up behind the 454. I have a 4l80e that needs a rebuild, but that adds to the cost and I'm trying to keep it down.
One thing I haven't even looked into is a carb. For that I want something that's cheap, but will get the job done. I plan to put fuel injection on it as soon as I can.
For a compromise of wheeling vs economy, I'd hunt for a qjet. Look for folks selling complete motors and see if they'll separate it (and the accel cable bracket).
Do you have brackets?
Accessory brackets? I'm going to get the kwik performance adapters and run the TPI serpentine brackets and accessories I'm running now.
268H.......a thought you wanted a BBC?!
I'm sure this engine will put out around twice the hp and torque my 350 puts out right now with the baby 268h cam. But run the numbers with the 270, if it's more than just a little better I may run the 270.
I haven't driven my engine to any extent at highway speeds....mostly because I was having death wobble issues when first put together and run at Moab. We did drive it out to BFE (~15mi?) and the engine and drivetrain were fine, no surging, no flat spots, etc. I've driven it to work numerous times at 60-65mph but that is with the FAST on it now. But driveability is fine....my cam really isn't radical by any means, just a real nice torque curve and BBC's love a decent amount of lift anyways with the 781's!
here is a brief description of my head flow #'s and a Dyno 2000 synopsis of my engine:
So my head guy emailed me the flow numbers for the 781 Oval Ports....
intake exhaust
.100--86 73 @28"
.200--169 128
.300--237 194
.400--285 216
.500--318 227
.600--319 227
Never had heads flow benched before....anyone know how these numbers look?
I just went to the best guy I know, and let him handle it....
by entering those flow numbers in my Dyno 2000 program, with small tube headers &mufflers, 800cfm dual plane intake, 9.4 compression, cam +4 advance....I get a peak of 470 hp, and torque peak of 550 @ 3500. The torque is 525 @ 2000rpm, and still is above 530 @ 4500 rpm. NICE, this engine just keeps getting better.
I have that JET 800 Quad (36003) if your interested in it.... It worked great for me on the Maiden engine, then I let Adam try it on his 408, he couldn't get it to come off high idle or something....anyhow now it needs the top airhorn replaced (the acc. pump part of the casting is broken but I have one) and probably a rebuild as it has sat for 4 years now. $150 as is with a replacement top airhorn.
Imo, I wouldn't go with any mechanical type cam simply to avoid the periodic adjustment. Using one in a wheeler that sees a minimal miles per year would be no big deal but if it's a DD and/or seeing real travel time/mileage why go with something that requires more attention when you can achieve the same goal with a hydraulic set up. I didn't realize Dave's was a solid type cam but finding a similar hydraulic version should be easy.
Check it once in the spring & then drive it all year.....:thumb:
There's this one that's hydraulic, but the only thing that's the same between the 2 is the intake duration.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=395&sb=2
11-207-3 Cam.....
389hp @ 4500
499TQ @ 3000
That's 11 hp less and 1 tq more at the same rpm for tq and 500 rpm less for the hp. But it's a hydraulic cam
when i pick my truck up friday.. ill be getting my new qjet that I just replaced off and into the for sale section it goes... hah... so def check the classifieds for carbs!!!
