Big Block Swap
ledfoot
Has anyone swapped a small block for a big block? How hard is it? Will I need different motor mounts. Also, I have a 700R4, will I need to do anything with it, like move it forward or back.
I believe just about everything bolts right up. You'll need a bigger ratiator, just go to a junkyard, or a shop, and get a radiator from a Suburban with a 454 in it. That bolts right in too. I dunno what year yours is, but my Dad put a 454 in a '83 with no trouble, like I said, it all bolted right on, might be different in later years. I'm not sure about moving the tranny though, my Dad didn't but his was a stick.
<font color=red>If it's stupid but works, it isn't stupid.</font color=red>
I am putting a bigblock in my blazer. after much research, I have found alot of money would have to be spent on the 700r4 to make it "reliable". we all know these trannys are weak, and much money is needed to make them stronger. I have decided just to use a th400. I would like to have kept the 700r4, but nobody could make me believe it would last. I hate being broken 20 miles in. THAT SUCKS!!
your right. I don't understand the jeep thing!
you're back to the old question of "wind it tighter" or "let it loaf". Spending the money on the 700 will probably work, there are a lot of shops that know what they're doing with them, but along the same lines, why not just build the heck out of a small block? because you'll spend more money and put a lot more stress on the parts than you will with a big block. it's the same way with a trans, do you stress the heck out of the 700 or loaf a 400. i say loaf the bigger trans, that way any material defects in any of the parts will not be as likely to show up. The big problem is lack of a low 1st gear and overdrive. Not much you can do about that.
good luck
SW-ORD
you could always try the 4L80, the overdrive TH400. i have been thinking about this swap, but over here big blocks are hard to find. i am debating between a big block or a nice revving 383 for sand dune abuse...i mean...use.
but i have a 4spd SM465....will the bellhousing bolt right up?
Knife.
knife.coloradok5.com
thats what i was thinking, because i already have a healthy 350 in my other k5. all i need is the stroker kit. can anyone recommend a company that sells a complete...i mean COMPLETE kit? something that i dont have to balance or machine....just clean and bore the block and install.
Knife.
You'll need to get all of the accessory brackets to fit a big block. The ones from your small block won't fit. This is when it's nice to get a complete take out engine from a donor vehicle. It will have all that stuff with it.
<font color=black>HarryH3 - '75 K5</font color=black>
http://ThunderTruck.ColoradoK5.com
simply a 383 is a 350 block 0.030 over and a 400 SB crank. thats it!!
installing a 4L80 can be expensive because you need the computer thingy....JETperf sell them for astronomical prices. but i have heard you can get the same computer thingy from a diesel truck....or something.....anyone wanna add some more accurate info?
Knife.
You also need new pistons for the diff in stroke.You also need the flywheel/flexplate for a 400/externaly balanced sb.
And the harmonic balancer for the same application.The 4L80E
is alot doe,your probably talking $3000 for the thing!!I'ld do a NV4500 conversion and save a few bucks,nothing like a stick anyway.The best thing about a big block swap is you can run a stock reliable motor and have plenty of power,on trail rigs the more reliable it is the beter you are.Just my $.02,good luck.
