I did a search and can't find the answer. I am swapping from a 350 to a 489 I just built. I have a TH400 (I rebuilt that last year). Anyway, the braces that go from the converter cover to the plates between the engine mounts and the block, is there a completely different setup for a big block or are they the same? Because the plate is actually hitting the block near one of the block plugs before it would bolt flat against the block bosses. I could clearance the plate a little and make it work, but it also looks like where the rods mount to the converter cover are too narrow for the big block oil pan? So is the whole setup different for a big block or is it supposed to be the same? Thanks in advance...
