I have been reading around ck5 to learn about this 76 3/4 ton big hub d44 that I have. One of the dials is broken and I need to replace it. If I can't find one at the jy, I was thinking of swapping internal hubs onto to it (my rings are a little banged up too).
I know I have the second design axle with 2 in. 'big bearing' spindles (same as internal hub spindle, right?). I know it is the rare second design with external hubs due to 3in od axle tube, round top knuckles, and tie rod ends. (1st design came with 2.75 tube, different oriented TRE's, flat top knucks, and small bearing spindles according to what I could find here).
Can I just swap the hub/rotor assembly from an internal hub donor? Will my stub shafts work out? I figured this would be a better option since the parts are easier to find for the internal locking hubs.
Patiently awaiting your expertise,
eric
eric
never seen that before.
