87 Blue Beast
what are you guys doin with your front axles? i just got my 10* shims in and it makes a really bad angle for the bolts to thread into the housing on the pass. side of the axle.
i know, but i also moved the alxe 1" forward with a zero rate, and since its moved up the spring alittle more, it takes away alittle from that 10* shim. so it really only turned the axle about 8*
thats alot of shim
i have 8inch springs and 6 inch shackles, and i only have like 5 or 6 degree shims
and you have an automatic tranny, correct? if you do, thats why. manual crossmembers are alittle over 2" forward compared to autos, which doesnt help the angle at all.
yzeater, its not crossover *yet*, because im swapping to crossover when i put everything back together. i dont have any steering on it at the moment. i just got the u-bolts back on and tight, so that is next on the list. ill get some pics when its done.
