drop the hammer
Well I thought I was sitting pretty with my tranny swap. Put in a 465/205 combo, NON-hydro manual clutch set up. My propblem it when I have the engine running with the clutch in everything is fine. The truck currently doesnt have axels in it. the moment I start to release the clutch, no matter what gear I have it in, including the wobbly gear ( Neutral), I stops the engine cold dead. It doesnt matter how hard or easy I let off, nor the amount of gas, theres a little clutch slipping together as if I was about to engage and then dead. I would figure if I had it in the granny gear, no drive shafts, engine running clutch let out it should just turn the output shaft in the 205, which was also moved through all options. I think I had the output shaft spinning maybe once. I just dont get what would cause this, need help. Maybe I am just thinking in the wrong areas, could the 205 but seized up in some way? Ws ablo to spin everything freely by hand before I installed it all. Everything apears to be lined up properly, care was taken while the combo was installed to make sure the throw out bearing lined up nice and the splines of the 465 slid in nice. Dont think its the clutch cause while the petal is depress all is well. I am stumped, humbled and kneal before the knoledge of the forum. Also cant get 465 into 2nd, just fights me. It will go into all the other gears with no fight what so ever, but I believe this could be the least of my worries
