goathearder
Hey Everyone,
My Blazer is a 73 with a 350/350 drivetrain. When in park, it idles at about 1000 RPM however when I put it into drive, it drops down to around 550 or 600 RPM! This seems a tad excessive to me, I am used to a 100-250ish RPM drop on previous carburated vehicles.
I did some reasearch on the internet and most everyone seems to say timing and fuel mixture are the usual culprits on this so I checked my timing tonight and have it at 14 degrees advanced (12 is stock but 14 seems to be the best for me).
I also checked the idle settings and the fuel mixture on the carb and that seems to be really good as well so I don't think either of those are causing the issue.
I did notice something curious when I was checking my timing though, If I have the vacuum advance on the carb disconnected (vacuum line plugged of course) the motor idles around 750 RPM in Park and when I put it into drive it drops to about 500-550 RPM.
It seems very odd to me that I don't have the same amount of RPM drop with or without vacuum advance on the carb. It seems even more odd to me that the RPM seems to drop to the same setting irregardless of whether the vacuum advance is connected.
Would there be something I don't know about that is essentially forcing the motor to drop a certain amount? Something I could be overlooking?
Thanks,
John
Thanks,
John
