For what it's worth, I have a 90 with 4" of lift. It did fine with the 33's but when I went to a 35x12.5 Mud Terrain, when fully articulated it will rub even with the fenders trimmed, With a little more trimming, I think the problem will be solved. But 37's would be an issue, for sure. Here's a photo of how much was trimmed (which wasn't quite enough) just to give you a reference. However, I'm running a D44 up front and a 12 bolt in the rear, so that will most likely change how much clearance you'll have in the fender well. With the 35's I was hitting the rear fender lip on the front and the front fender lip on the rear, again, only when it was twisted up and the wheels were turned at the same time, but the swaybar was still connected. You can see the rear fender lip is bent a bit, no need for trimming now, since that fixed the issue. Point being, no way to get 37s under that without some sawzall work.
