A set of mild mud terrains is what you want. Reputable brand hard to go wrong with Good years MTs or BFG MTs. I personally like Yokohamas too. Toyos are good if you are willing to give up a bit of off road performance for on road wear and performance.
One thing I always thought looked " wrong" with our trucks is the fact that the rear axle is so much narrower than the front, I think wheel spacers would be a dandy addition to get the overall "look" how you want it.
Those fender flares do very very little for overall tire clearance but I have in the past trimmed out a couple of flares like that ( for Fords actually) and came up with a bigger wheel well opening to fit a bigger tire and had the flare look very intact from the outside. We did have to use some epoxy on the flares and get creative mounting the lower corners but it worked well.
Like I said moving that front axle forward is a good way to fit bigger tires and while the ez inch is an easy way to do it, same can be done with a drill just redrill the holes for the center pin, moving that front axle forward an inch will do wonders for tire clearance
Not everyday you hear or see the word "dandy" thrown around.
