quinryan
I have an 82 Jimmy with the 6.2. For once, the engine isn't the problem.
I took the instrument panel apart in order to replace a broken fuel gauge. While I had it apart, I replaced the bulbs (red ones. Looks cool) and before I put it back together, I made SURE that everything worked right.
Then, I had to fiddle with the headlights. I have the 4-light system, and the new high/low lamp on the passenger side had a bad high. As the lamp was new, I figured that something was up with the wires there. Took it down, played with the wires a bit, and it lit right up.
Put together the I panel, and all was right with the world. Until...I turned the lights on later that night, and lots of odd stuff occurred.
-Fuel gauge goes to zero.
-No panel lights at all.
-the passenger side Low beam is inop.
-The I/? arrow for left turn stays on constantly, while the right side arrow doesn't glow at all. The turn signals work properly though, as do the tail and brake lights.
-Oh, here's the really weird thing: the little lights that indicate High Beam come on when the Low beams are on, and when the High Beam comes on, the lights go out.
Any ideas?
Any ideas?
