I’ll check into that, it will probably be easier if I just buy one, I live 75 miles from closest auto parts store.In that case I’d gauge a fuel pressure gauge to see what’s happening. Most parts stores have a kit in their loaner tool program.
Actually I’m not sure about that, have to check that out.Does it do it on any steep hill pointing up, but not pointing down?
I run the autometer gauge inside my truck. It plugs up behind the tbi unit, they are over $100 but very worth it if you plan on keeping tbi.
Probably a dumb question but, Is that an electrical plug ? This TBI stuff is all new to me .I run the autometer gauge inside my truck. It plugs up behind the tbi unit, they are over $100 but very worth it if you plan on keeping tbi.
It uses an adapter on the fuel line with an electric sending unit. Its a nice tool to keep an eye on pressure conviently.
Hot damn, I wished I knew about this design of gauge in my past vehicles. It probably would’ve saved me a ton of time and money . Thank YouSearch through Autometer products, the mechanical gauge uses an isolator so there only fuel in the line on engine side. You’ll mount the isolator on the firewall and then there’s a special line that goes to the gauge, this line has a non flammable liquid (antifreeze, iirc). These extra pieces are why this set up is a couple hundred bucks (as opposed to a $50-$75 stand alone gauge).
There is no fuel inside the cab.
