Blazer Bash 2020 last minute thrash
Discussion in 'Blazer Bash' started by ktmoutfront, Sep 23, 2019.
  1. fastazz81
    fastazz81 Gnome recovery vehicle Premium Member GMOTM Winner
    Dec 21, 2007
    1,721
    2,951
    spanaway wa
    Build(s):
    So far, it could use some tweaking , runs s little fat at idle . But runs so much better and fires right up and goes so I’m going to send it.
  2. ktmoutfront
    ktmoutfront GnomeWorks LLC Premium Member GMOTM Winner
    Feb 20, 2007
    20,491
    27,715
    Somewhere being famous.
    Build(s):
    4
    My biggest cluster of the day was,
    I started filling the camper water tank. Closed all of the drain valves and started running water slowly. Went to do some other stuff as it usually takes 20 minutes. 5 minutes in there is water running out from under the camper right under the water tank. This is a 1997 Lance camper, so I was not surprised that something might be cracked.
    Shut the water off and start looking under the semi to see where the water is concentrated. Right under the water tank.
    I start looking at what it will take to get to it. It is under the step for accessing the overhead bed. Screws are under the carpeting that has been trampled on for 23 years. Could not find them. Tried using a magnet to locate them. No luck. Ended up tapping a screwdriver with a hammer to hear it hit something. Found 3 and it still would not come loose. 4th one right next to one I removed.
    Cover came off and I could not see anything wet. So I start looking around more. Turns out, I turned all of the drain valves 90* to the line. All ball valves work that way. Nope. Not the little drain at the back of the camper. 90* is open. Semi was sitting nose down. The water drains onto the tool box then ran down to the front. When I drain the system I put a hose on it and run it off the side.
    So I put everything back together and just waisted another 1.5 hours for absolutely nothing. Seems to the norm a little more lately.
    500$k5, 76zimmer and Capt Ron like this.
  3. Bent77
    Bent77 lil meanie Staff Member Moderator GMOTM Winner
    Dec 3, 2002
    32,773
    43,195
    NoCo
    Build(s):
    I hear Moab helps cure a case of the Wades
    500$k5, 76zimmer and ChrisPerry like this.
  4. 6872xtc
    6872xtc make mine modified Premium Member GMOTM Winner
    Sep 16, 2008
    6,916
    6,673
    Palisade,Colorado
    Build(s):
    I seem to play with a few settings here and there. @Bent77 seems to have no problems. I discovered that the automatic transmission and A/C required me to turn the self learn RPM up before hitting the trail, or it tried to learn on the trail and got messed up!
    500$k5 likes this.
  5. Bent77
    Dec 3, 2002
    32,773
    43,195
    NoCo
    Build(s):
    Yeah I’ve plugged it in once. No idea where it’s at. Afraid to reconnect and mess it up
    Get the winch done?
  6. 6872xtc
    Sep 16, 2008
    6,916
    6,673
    Palisade,Colorado
    Build(s):
    I don't remember who you are talking to....
    :D
    I never hooked the batteries up yesterday, but I swapped in the brand new tie rod ends, to replace ones that weren't worn out, just unknown age and make. They weren't really tight in the knuckles.
    500$k5 likes this.
  7. Bent77
    Dec 3, 2002
    32,773
    43,195
    NoCo
    Build(s):
    Seems to be a thing
    so wireless winch huh?
  8. 6872xtc
    Sep 16, 2008
    6,916
    6,673
    Palisade,Colorado
    Build(s):
    Yeah, after hearing of someone else's problem, I wanted to check mine.
    And I have cables all done, just have to connect the 2 ground cables at the batteries. Didn't get my butt in gear soon enough this morning to have a easy start to the day, (Sunday) AND go finish a couple of things on the truck. So I went with the wife to buy things for this week.
    500$k5 and 76zimmer like this.
  9. Fastereddie
    Fastereddie Sorry if I offended you. Not. Premium Member GMOTM Winner
    Aug 6, 2016
    4,412
    8,070
    Henderson Nevada
    Build(s):
    Over @Desert_K5 , I got the track bar spacer moved where I wanted it, got the 205 front output yoke clearanced and new Tom Woods shaft in. Ruff Stuff rear cover is on too!
    9ECCF3EB-B309-4243-A86E-98973B9470F3.jpeg 3F618EE7-4DB0-4D37-9DDE-BB45760F86B6.jpeg E2226540-E073-4039-92D4-29C5246B7630.jpeg
    Capt Ron, 72gmck5, 500$k5 and 3 others like this.
  10. DickeysK5
    DickeysK5 1/2 ton status Premium Member
    Apr 13, 2009
    354
    218
    Los Lunas, New Mexico
    Don't your dare. They made me quarantine and get tested after our Gates of Ladore, Utah raft trip at the beginning of August.
  11. Bent77
    Dec 3, 2002
    32,773
    43,195
    NoCo
    Build(s):
  12. Capt Ron
    Capt Ron Minus .7 liters Premium Member GMOTM Winner
    Nov 17, 2015
    1,700
    2,706
    Lakewood Co
    Build(s):
    This list was so woefully inadequate, getting a new truck ready for a camper, getting said camper ready, a few mods done to the crawler and a variety of things done to the trailer is giving me a case of the Wades.
    500$k5, Fastereddie and Bent77 like this.
  13. doubletrouble
    doubletrouble 1/2 ton status Premium Member
    Nov 3, 2010
    643
    267
    Milliken, Colorado
    After a long weekend of motocross racing now I have to unload two trailers and two trucks and start loading for Blazer Bash. Can’t wait to get on the road!!
    Fastereddie and 500$k5 like this.
  14. Capt Ron
    Nov 17, 2015
    1,700
    2,706
    Lakewood Co
    Build(s):
    I'm getting closer.
    skunked, ZooMad75, regal403 and 13 others like this.
  15. DickeysK5
    Apr 13, 2009
    354
    218
    Looking good :waytogo: Too bad I won't be able to see you wheel it in person.:frown
    Capt Ron likes this.
  16. Bent77
    Dec 3, 2002
    32,773
    43,195
    NoCo
    Build(s):
    I’ll teach him the “Hulk smash”
    Capt Ron, Desert_K5 and doubletrouble like this.
  17. Desert_K5
    Desert_K5 1/2 ton status Vendor
    Apr 23, 2016
    1,711
    2,806
    Build(s):
    ^^^ this I must witness hahaa
  18. Desert_K5
    Apr 23, 2016
    1,711
    2,806
    Build(s):
  19. 72gmck5
    72gmck5 Fix, break, rinse, repeat. Premium Member GMOTM Winner
    Jan 5, 2009
    834
    2,414
    West Jordan, UT
    Build(s):
    Last minute winch mount fab. Coming together nicely. Still have to build ramps for my trailer.
  20. 500$k5
    500$k5 wallet under gas pedal Premium Member GMOTM Winner
    Apr 17, 2007
    262
    855
    Montrose, Colorado
    Build(s):
    ZooMad75, oatsk5, ashman and 9 others like this.
