Blazer Bash 2020 last minute thrash
The Jimmy is done.
Oil change.
Air filter.
Checked all fluids.
Set tires at 36 psi.
Arranged the tool bags and re-strapped everything.
New brackets for the front brake lines added.
Welded a broken engine cage joint, again. There must be a lot of stress on that joint. Ripped the DOM the first time. I will have to run strap someday, but not today.
Ordered a new pressure switch for the compressor.
- Balance tires and rotate Done used balance beads, a pain to go through the valve stem but seam to really smooth out the ride.
- Buy 2 new hubs for spares Done
- Full Tune up Done and bought some spare stuff
- Oil change and air filter Done used old spare oil filter and bought a spare to pack
- wingnuts for air filter Done
- Move front license plate Done
- Mount GMC Emblem Done
- Move Fuel Pump
- Get spare Fuel Pump
- Check exhaust leak Done Broke exhaust manifold, new one ordered. Geez it only lasted 50 years, Junk
- Paint bumpers / Sliders
- Fill CO2 tank
- Adjust shifter linkage
- Adjust T Case shift linkage
- Refill fire extinguishers
- New CB Antennae
- Nut and Bolt Check
- Tie spark plug wires up
- Clean truck
- Pack
