Blazer Bash 2021 not Last Minute Thrash
Jeepsters had them from 66-70.
not sure about CJ’s.
might be better off with a 30 though.
I can't get my tcase in low, putting it on the trailer after work and headed moab.
Anybody up for helping get it in low?
It should be easy with the pressure off of the gears, as long as everything is assembled properly inside.
It bench shifted fine after the rebuilt, I think the adjustment is just out on the shifter and I cant seem to get it to hold while im messing with it under the truck.
Trans was in neutral like I have always tried to shift it.
Probably the shifter rod need adjusted after you fixed the body mounts.
Really just need to pull the shifter off, push it into low, have someone hold the shifter then match the plate onto the tcase and bolt it together. Need to do this also when it's cold and the exhaust is not hot....
Am fixed. Dealer didn’t understand the part where I said that Ford Parts said they had a boost tube in stock and gave me the run around.
Then asked me if I had a 6.0. No, if I had a 6.0 we’d already be on a first name basis.
The hand cleaner wipes are by Gunk, Lowe’s had them.
Dealership had these great F250s in classic trim.
