Blazer Bash 2021 not Last Minute Thrash
I noticed this last year but figured it was because of where I was parked. Looks like a bit more weight on the back axle then the front. I can put rollers on the back and get it further towards the front of the trailer. What say the peanut gallery?
If you can move it forward it would, but it may require more drop in the hitch if your tongue weight is correct now, or if you get too much going forward to level it out.
Kaboom. Pipe from boosty cooler to intake exploded.
It almost looks like you could clean the pipe and tube, get some hair spray on there and a couple worm style hose clamps. Spray the tube and pipe good with hairspray, slip it all together and tighten the hose clamps up. That might let you limp to someplace with a tube, (Ford Dealer) or order one and have it shipped to Moab Rim or if needed someone like me in western Colorado where you can get it or meet up in Moab. After market is better for this as this is a common issue.
Duct tape. That is after the inner cooler? or going in?
That's post turbo and inter-cooler. Anything done will have to hold up to 20+lbs of boost depending on stock turbo and any tuning that may be done.
The silver thing is the throttle body. This is a common 6.7L Ford issue and several aftermarket companies have solutions.
I’m parked for the night in Salina with a Lowe’s next door. I’m going to let this cool off and try to get it clean.
I tried some tape on the side of the road, but it wouldn’t even stick to itself.
Once clean, hairspray acts like a lube for fit up but then dries into a "glue" of sorts to help hold things together. Couple big 4" hose clamps and you may just get it to stay.
One clamp and tape held 9 psi. It did not hold 10. I’m calling it a night and rolling the dice on a speed shop or dealership in the a.m.
Side bar: I found these wipes at Lowe’s this almost instantly clean your hands.
Tube out of truck:
Tube out of truck:
Stupid plastic shit. My duramax has the same plastic crap on it. Hope you git er done tomorrow. What are the magic wipes called?
