Knocking stuff off my list.
Last weekend I flushed the coolant, added water wetter, changed the gear oil in the trans, changed the ATF in the transfer case, and the gear oil in the rear end. Lucas products for all. I was particularly interested to pop the cover off the rear since I did the grizzly Locker about 5,000 mi ago and wanted to make sure everything was legit. No sparklies or metal chunks so all good. Also changed some u joints and started doing a bolt check, and oh boy I found all the bolts on my T-case adapter were loose. Now I will check everything.
Today I'm going to change my spark plugs and change my front body mount bolts, as well as check the others.
I've been rounding up spare parts and tools since the spring and now just need to figure out how to pack it all efficiently.
Big stuff coming up:
I've got a Dana 60 on the way from Boyce Equipment, it is currently on a pallet on a truck somewhere in Idaho. I've got everything I need to do the swap rounded up so I can probably get it knocked out in a weekend.
I've also got a line on one of Engineered Vintage's first behind the bumper winch mount kits, which I hope will be in my hands by the end of August. I already have a winch so that should be about a day of work. Cool story is I traded my old Warn trans4ormer grill guard for this new winch mount.
With all that being said I'm super excited to get my big truck out on the slickrock and see what it can do and meet all you great folks.
