You did not let the techs touch it, right?
Oh hell no. I waited until everybody else was gone. I know better than that. Had the whole shop to myself. It's amazing what can get done when idiots are not constantly pestering me.You did not let the techs touch it, right?
Alex as in THE Alex?Front Axle all sealed up, waiting for Right stuff to be good and set up then fill with gear oil, Rear ARB fixed, installed and dif cover back on just waiting for Right stuff to set and axle shafts.
ToDo
Install rear axle shafts (Clean up hub faces and axle flanges first)
Fill front and rear with gear oil
replace output housing on 205 (driveshaft out etc as part of this)
Install battery and start it for the first time in 22 months ( do this sooner rather than later)
Skid Plate and panels
Winch control switch replaced
Install GPS, headsets etc (all plug in crap but needs to be done)
Find or make two tires usable
Pack tools (Filling tool bag with tools that are needed as tasks are finished already so this should be somewhat easy)
I've been working on this in my driveway but since it sounds like rain in coming later this week I better get it off the trailer and into the garage so I can putz with the easy things in the evenings. Hopefully by Monday morning next week I can load up and make things ready to go.
Edit: I also just registered Alex, my copilot who helps me make poor life choices, it's been a few years since he has been to BB with me so this should go terribly for our livers.
Sounds like a normal BB to me.Edit: I also just registered Alex, my copilot who helps me make poor life choices, it's been a few years since he has been to BB with me so this should go terribly for our livers.
Like Alex Santiago the Puerto Rican, his people are swimmers not runners. YupAlex as in THE Alex?
Wow! Can you quarantine while working on your truck?Well a monkey wrench got tossed in the fire today...
My roommate tested positive, I did a rapid test and turned up negative. I can't go into work until monday without a negative test again and I feel perfectly fine right now. Looks like I get to quarantine Moab prep. Hopefully I don't come down with anything or I will have to cancel.
I'm on the side of my brother house in his trailer camping out away from everyone.
That is the plan, I loaded up the truck and drove it here.Wow! Can you quarantine while working on your truck?
We will wait and see, taking all the precautions I can.I felt fine for about 5 days after I was exposed, then it hit me.
