Blazer Bash 2022 trail requests. Registration is open. T-shirt sales end August 8th.
Saturday is the Plane crash lead by ZooMad75. Thanks.
I was hoping to do Kane Creek on Saturday. Because it can be time consuming with the larger group, or if I put the Jimmy somewhere that it should not be, assuming I take it and it survives until then.
I just always assume you will lead Pritchett one day. Thanks.
What’s the plan for a BBQ safe trail?
I wouldn't mind trying crack and back.
Still can't remember the name of the rock pile coming off the trail after the crack but I would like to see if my truck could make it.
Probably thinking Butt Scratcher
Whatever you want to lead.
What would be considered a bbq safe run?
Obviously closer to town.
Is metal masher too hard? Are there by passes around the wall and the fall? It’s close for sure.
It’s a ways from town. Also a push to push the taco truck through it
Ok, I had the wrong name of the trail I was thinking of. Steel bender was the one I went on with @AgDieseler.
What I’m not sure of is the harder obstacles at the end that we turned around and came back before hitting. I don’t know if there are ways around it. I suppose I could probably just take the hook right away and get over it.
As long as we get tacos for lunch, and not tossed empanadas
Metal Masher, Steel Bender. Sounds the same for body damage. Actually none for either trail. Steel Bender leaves from the park on Friday morning if it gets ran. There is a short or long trail. There is one down hill running that direction that gives a pucker factor. You should be ok though.
I am going to be honest here. I am bored with Moab. The only fun for me is seeing everyone and hanging out. I would be OK with a chair on main street watching the world go by. So you all need to step up with trails.
We could do the Shaffer Switchbacks, Muscleman Arch and Laverne and Shirley leap on Friday for the newbie easy run.
I think you need to do the Thelma and Louise leap
Steel bender wasn’t that tight at all. Pretty wide open. I made it through as far as we did with the camper with zero issue at all as far as camper clearance was concerned. It’s got some fun challenging areas I wouldn’t take a stocker on but it is a really cool trail.
:haha:
We were talking about Zoo’s Taco wagon, I was following along!
