ratki
Registered Member
I recently installed a 97 5.7 Vortec into my 82 K10 and also found the fuel to be the most troubling/concerning. Luckily the 87 came with TBI so I bought a new 87 tank with the internal bowl/baffle where the pickup sits. Installed a Delco EP381 fuel pump into a new 87 sending unit and it was a perfect factory fit. I think an EP241 pump would provide the pressure you need. I weighed many different options myself with the fuel lines and ended up using Russell push lock. Heads up though, they ship Parker 836-6 hose so if you have a local supplier just go to them. The - number is the size; in this case 3/8. Use the AN push lock fittings and then get some adapters for fuel rail to adapt to -6 and the rest is just running the hose. I used high pressure hose clamps to attach to the sending unit but plan to get some parker compression to pushlock. I felt the in tank pump would wind up being my best bet and with EBAY found my parts at a very resonable price. The one difference with you is the frame mounted pump. It would be best to find some sort of 3/8 barb that would allow the hose to fit nice. The a bit larger as compared to hard line, but man is it much easier to run.
