I have been absent from the thread for several months as I built a new garage on our property. Now that it's done I am making preparations for installing a two post lift. I need to know the height of the K5 Blazer from the bottom of the frame rail to the top of the cab and hardtop. My K5 is 100% disassembled
The reason I ask is my plan to install the two post lift is on hold until I determine the type. I am either going to install the two post lift with the bar across the top or the bar across the bottom. I was hoping to install the two post lift with the bar across the bottom however I am hearing that it interferes with transmission removal. The bar across the top is concerning because it appears to me that it would limit the height that the Blazer could be lifted into the air. And that is the source of my question, what is the height of the Blazer from the bottom of the frame rail to the top of the cab.
If I can lift the Blazer high enough in the air and not hit the cross bar then I'll go with that type of lift for the security and extra strength with the bar across the top.
It seems the lift with the base plate can provide 7 ft of lift from the bottom of the lift bars and the two post lift with the crossbar on top can provide 6 ft of lift. I'm 5 ft 10 in tall so that should probably be enough but I'm still concerned about the crossbar hitting the top of the Blazer there by lowering the maximum height I can raise it.
Any experience from anyone with these types of lifts installed in a house or work environment? Any Brands to avoid or any brands that are highly recommended? I'm looking at a 9,000 lb lift but never anticipate lifting something that heavy. The posts will be installed in the garage where I dug out 12 in for for Footers. We used wire rebar and we later strapped 1/2" rebar to the wire (2' lengths in checkerboard pattern).
