This thread is for the general discussion of the Item Blazer's 84 Blazer. Please add to the discussion here.
The problem is finding a 2wd BlazerGood luck! I'm taking my body off the frame today. Might be wrong here but I was thinking it was easier to go 2wd to 4wd then it was to go 4wd to 2wd, but I could be way off. Should be everything you need to know on the forums. I think the only mount for the body that's different between the two wheel and four wheel drive is the one under the core support for 81-91.
Especially a 2wd frame that'll fit your Blazer since the 73-77 won't work.The problem is finding a 2wd Blazer
