88k5blazin
i got the hydro setup and i had it workin good before i had to change the clutch out now i lost clutch pressure and only have about 50% travel. ( never opened anylines while it was sitting) when i started to rebled the system i started getting black fluid coming out of the bleeder screw does this mean the slave cylinder is bad. also do you pump pedal then crack bleeder or crack bleeder then pump pedal. auto zone had good directions that worked perfect the first time then they took away the tech section so i'm lost now
