Bling Bling!!!
oooo aaaaa
looks sweet. how much did that set you back? besides the additional 1.44 low end, what made you choose that case over a doubler? weight?
I got it for $1800 to my door. Thats at cost.
Besides it having the lower gears I dont like the doubler because its to long for my taste, heavy, and I would be in it about the same as I paid for this.
See the thing is with my truck , everything that I buy I buy for when I build a buggy some day. My goal is to one day have a small 2 seater 1ton'd buggy. So the Stak was a perfect fit for me.
well you are well on your way:bow: $1800 isnt bad at all. i take it you have a hookup. what do those things usually run?
muddybuddy said:
well you are well on your way:bow: $1800 isnt bad at all. I take it you have a hookup. what do those things usually run?
They usually run $1899, then shipping is about $100.
Heres the new skid.
First I made a frame out of some 1"x.120" square to keep the plate from bending.
Heres the frame bolted in. There are 4 3/8" bolts holding it on. Yes a socket fits around the head of the bolt in the tube 8) Should protect the bolts from rocks.
Layed some 1/4" plate on it 8)
Here it is installed. My belly height is 26".
85mudblazin said:
Just a 1" zero rate......
really? muddy beat me to it but I was wondering the same thing. They sure look like more than 1" zero rates. Nice work btw!
-Avery
Bingo! I thought that perch was part of the block/zerorate.
Man that is beefy!
-Avery
you mean, bling bling cutting, brakes?????????????
or the other shinny, blurry pic, too hard to focus 6:30 am
sweeeeeeet
sweeeeeeet
I know what you mean gabe, school has kept me up until past 1:00 every night so 6:30 comes early. :doah:
-Avery
