Man what a nice blazer to blow some snow. Couldnt you have boughten a rusty one
Should be cool though
Should be cool though![]()
Haha, I know you have salt; I just wasnt sure of the way in which the DOT treated the roads.. For that matter, what are your plowing practices? The reason I ask is because you mentioned flotation tires which "usually" isnt synonymous with plowing at least in the north east. The classic plow truck is like a 70 some odd ford f250 w co-op grip spurs or something like that.. Not knowing any better I guess I'd vote for, maybe if they still make them, some classic buckshot Q78s; I think they have stud holes. I know you said you run chains but the addition of studs cant hurt... We ice race up in the mid coast region where I'm from and we use to get some "take off" winter rally tires but then we found these tires called "black rockets" which are a narrow, deep, radical ice tire; they work boss in most race conditions...Anyway.....A little long winded sorry.... We sourced some studs like the ones that came in the black rockets but longer and they DIG like sum-bitches
Maybe a combination of narrow buckshot type tire and long studs would work like
We usually drive 100-150 miles on bare tar (stud heat) carefully to seat the studs to the rubber, this way they have less of a tendency to pull while spinning...
Pic; Black Rocktes and "special" unlimmited class tires.....![]()
I will be following your build. I have debated converting to a blower setup. This is a portion of what I plow.
Also, the pic of the transfercase output shows the slipyoke to be a little extended, indicating to me that it's not at stock height.
What you're seeing is the 'travel' of the slip yoke in and out through the 'bumps' the suspension sees. 5 plus O/L in the rear is stock, three up front is common enough too, although a lot came with just two. My 90 had a three leaf pack up front too.
Sheee-it, for $500 you could get a new "kit" with shocks in a 4-6" flavor. I paid $200 for a 4", front springs, rear blocks, all new U-bolts. Shackle flip can be done for 'free' in the rear, if you're 'inclined'.
Keep your eyes on the classifieds here, you may find a lift that someone else is removing for less than what the kit you are looking at is. 6" is going to require driveshaft modifications, while a 4" varies as to whether you will have to do it.
By the way, nice Blazer, loving the look so far and the work you are doing.
