I was offering him my 3/4 ton axles with 4.10 so he can have 35" tires run good for his purpose.If your gonna go to 37s or 38s I'd look at swapping in a 9.5" semifloat 14 bolt 6 lug.
This is out of a newer truck and is not a bolt in. Spring perches and shock mounts need moved.
Your other option is to find some 3/4 ton axles from another square body. Those are direct swaps. You'll just need 8 lug wheels.
But, I guess he wants the look of 37-38" tires, and although he can do with 4.10 spending a few minutes on this forum 4.88 will be the minimum he wants and I know most will convince him to go 5.13
I am offering him now the 4.88 from my blazer with the 37" on it, or the 38" that I have for sale.
The way it is now with the 350/th350 it's overgeared, anything above 58mph the engine is getting a little warmer from high rpms so with the 700r4 it will be perfect with either tire.
What do you guys think?
