Boatsided crew cab with doors
I have talked about that style of frame beef in my mind it should work well. Did you add any crossmember in the middle?
I think that helps alot too
I understand that you started with the suburban frames, but I wonder why you kept going after you found the k30.
Why not build the k30 frame?
I didn't want to shorten the frame..and I had a alot of work already done to the suburban frame.
