Boatsided crew cab with doors
That thing is tall judging by the way the seats just slide under the frame like that.
I’m going to do the bedliner in my cab this summer too, so I’m digging the in process pics. Did you have to remove any excess factory panel seal from your floor?
You are doing some very high quality work on this truck.
Its sitting tall because it doesn't have any drive train in it right now...the floor I just cleaned with a wire wheel ... you can use it to shape the factory seal and primed it.
The sight tube I added to mine came in handy on the first test run. The output seal blew out and I was able to see I still had enough fluid in the case to continue on.
