body lean
August
Spain
Hello,
My 1980 GMC Jimmy has a little body lean on the passengers side, near a inch. Is it normal? Could be a bad leaf spring? Do I have to put new ones?
Can be repaired?
Thanks
August said:
Hello,
Can be repaired?
Thanks
Could be suspension, yes, or could be body mounts.
First check tire pressure :) ... then measure from the frame to the ground. If it's the same side-to-side, measure from the body to the ground. This would mean you need new body mounts or something.
If the frame measurements differ, then I would take the springs off, make sure no leaves are broken, and switch them side-to-side. This might cure it :)
-- A
