i have full set of 8 nice light use 3" tall but light dirty body lift blocks.
$35 shipped to you
need gone asap.
$35 shipped to you
need gone asap.
anyone lookin for a set ?
i need about 6 of em to cut in half
That is weird, all mine are extruded the same profile from top to bottom, I am planning on cutting mine down too but from 3" to 2" to match the other 2" I have.not recomended.
if you cut directly in half you loose all the strength.
thay are honey comb in the construction. then 1/2 way threw all these body lift blocks thay twist to off set the internals.
so if you cut these in half you losse tons of strength.
here is a round performance acc block. then a hex shaped trail master block.
with the line you can see what i am talking about for loss of strength if you cut it directly in half. you loose the factory core shift that gives it lots of strength over a std top to bottom style.
1/2 way its a full out of alignment twist.
