body lift blocks cheep
sweetk30
Back to play nice .
in the back of your brain
i have full set of 8 nice light use 3" tall but light dirty body lift blocks.
$35 shipped to you
need gone asap.
i need about 6 of em to cut in half
not recomended.
if you cut directly in half you loose all the strength.
thay are honey comb in the construction. then 1/2 way threw all these body lift blocks thay twist to off set the internals.
so if you cut these in half you losse tons of strength.
not recomended.
That is weird, all mine are extruded the same profile from top to bottom, I am planning on cutting mine down too but from 3" to 2" to match the other 2" I have.
here is a round performance acc block. then a hex shaped trail master block.
with the line you can see what i am talking about for loss of strength if you cut it directly in half. you loose the factory core shift that gives it lots of strength over a std top to bottom style.
Is it a sudden twist or is it s continuous twist?
when you cut it down, it will not really need much strength since it's not too long. :waytogo:
I will look at my 3" again to see if they have this twist too.
i dont care. just stating my feelings on cutting them directly in half and posting pics to prove what was asked.
if you want them good. if not thats fine.
