Body work help??
BlazerBoy
Chicago IL.
I am working on the body work to get my K5 back together. I have some pitted rust on the rear lower quarter panels behind the rear tires. I have sandblasted the rust. I cant get it all out because of the pits I guess. So what should I do to finish removing the rust and then how to repair this area? body filler? I would like to do something that is very durable because of how prone these areas are to rust... thanks any advice is good advice...
BlazerBoy
http://generalblueballs.coloradok5.com
I dont know about the rust but I had to fix a dent on mine there and then got it line-xed to hide it
Go prepared
</font color=red>90 k5 soon to be big, bad, and mean
Try getting the area as clean as you can then use Por-15 on it. The Por-15 will chemically change any rust that is left, so I don't think you should have a problem with it. That's just what I think (and would do).
72Blazerod
p.s Por-15 does have a web site with more info but I cannot remember the exact address right now, try
www.por15.com
If that's not it, I'll try to get it to you later.
