bother with the speedometer?
use the speedo?
  • yay
    Votes: 8 32.0%
  • nay
    Votes: 12 48.0%
  • i use my GPS as a speedo, while driving in my prius.........nekkid!
    Votes: 5 20.0%
  • Total voters
    25
NEK5
3/4 ton status
Ipswich MA
As some of you know, I'm opting to keep my rig as trail only.
With that in mind, I'm wondering how many that have a trail only rig, bothered with hooking up a speedometer?
I wouldnt... If your curious about the speed then the GPS works great... Thats what I use.
It depends on the year of the vehicle and if it uses a VSS. If there is a VSS involved then you really need to hook it up so the VSS works so that the ECM can use it for it's needed purposes.
Mine's not hooked up. If I end up driving it on the street I will just use a gps. Once the factory gauges go, there will be no speedo gauge either
Where is the option for "I drive mine on the street with no speedo"?
Martin
If your gonna register it, why not put a speedo in it? The cable is cheap and it's better than getting a ticket the first time you go out for speeding..
i just go with the flow of traffic, and use the radars on the side of the road to know rpm @ certain speeds.
Go by the tach. My mom had no speedo in her '81 T/A. We just went off the rpms. Never once got pulled over ;)
its electric, and i'd have to re configrue the DRAC to make it right
Yah, just do the DRAC mod. I'll even send you the 7pin dip switch you need to do it.
Just sent one to jonathan.
When i ordered them to fit, i had to by like 5. Don't think i'll have 5 rigs that need drac switch mods in mylife :haha:
I dd my truck and dont bother with the speedo
I have a tach and can figure my speed pretty accurately. Ive driven with no speedo for the past 6 years and been pulled over for everything but speeding.:D
watch, Ill get a speeding ticket on the way home from work now:doah:
i haveny had a speedo in like 3 years either .... i just drive and in our heavy trucks who needs to speed anyway ??
