Thats one of the mods I want to do for my 88. I would assume its a pretty simple mod but let me know.
Are you going to move the gas over to the small gauge cluster?
lol....Quartz Hill is the Beverly Hills of (West) Lancaster up in the Antelope ValleyWHAt - that was word for word what i was going to post!
wheres quartz hill? - you must be reading my mind from quite a distance!
Looks good. Thats the plan for mine. I found a factory diagram, no repinning needed since I found a 79 printed circuit for it.I bought a used one here in Denver. I never had to re-pin on my 79. Just worked. Not sure if they changed the back plane in the 80s. I did buy a tach harness for it and it was better than trying to use some cheap spade connectors since those would sometimes fall off. I just cleaned up the gauges (very carefully) and repainted the needles on speedo and tach. New lens too. Also swapped the original speedo so the miles matched.
