So yeah. Back to this. Didn't fix it.
After the February debacle, replaced the defective (new Delco, maybe 5 years/30k on it) oil pressure switch, re-mounted the relays more securely, and re-did some questionable wires. Quite convinced I had solved the problem.
Last week driving, repeat of California trip. The problem had not returned in over 6 months of driving, although under 5K miles. This time however, I was not in a hurry and could sit and think about it. After stalling on me, it would fire, sputter, and immediately stall. Sometimes I could get it to sputter for longer by varying the throttle. Eventually it wouldn't fire at all, just crank. I noticed I wasn't hearing the fuel pump prime, so I ran 12V to the pump wire, and the pump wouldn't run. So it's either the pump, or the wiring to the tank. I'll verify. FWIW before this last trip, I even borrowed the fuel pressure tester and took a test drive. No issues with the pressure.
IF this is a bad fuel pump, I'm going to begin to question the quality of Delco products. This pump is also maybe 5yrs old and has 30K miles on it. As an aside, the first oil pressure switch/sender failing was unusual, as they should last far longer IMO. This BRAND NEW switch/sender however, has also already failed (stuck closed, which runs the pump even with the key off). I don't see any reason these would be failing based on the location they are mounted. Far away from the headers, the connector, wires, nor sensor body show ANY sign of heat exposure above normal underhood temps.
Much of this at this point is cautionary, in case anyone else happens to run across these symptoms. I'm going to verify the pump issue, but I hope now whatever has failed, has completely failed, and isn't intermittent. So I KNOW it's fixed this time.
