Probably--but if you have no one around to help (or they fail to grasp the proper procedure--pump it up,"hold it down","UP.etc ),it can be frustrating to do with 2 people..they goof up once and air gets pulled back in and you have to start all over..
I bleed brakes alone by using engine vacuum ,all you need is a long enough hose with a 3/16" I.D. to reach all 4 wheels,another piece a few feet long to hook to an engine manifold vacuum source, and a glass or thick plastic jar with a metal screw on lid,and 2 short pieces of brake tubing 3/16" diameter..clear vinyl hose is cheap and perfect for this application..
You poke 2 holes in the metal jar lid,stick the 2 pieces of brake tubing thru it--one goes right to the bottom of the jar,the other one you only want to just go thru the lid about 1"...you can use glue,J-B Weld or solder to secure the tubing in the lid and make it air tight...add enough brake fluid to the jar to cover the longer tube ,you only need an inch at most..just to keep air from being able to sneak back the other way..
You then hook the shortest tube to engine vacuum,and the longer hose to your brake bleeder--I used vise grips on the hose from the bleeder as an on-off valve..hook up the long hose to the bleeder,start the engine,open the vise grips,and watch the fluid get sucked into the jar..when you see no more bubbles coming out of the hose on the bleeder,close the bleeder,pinch the hose off with the vice grips,and move on to the next bleeder..
In a pinch you can bleed brakes this way without the jar--all you need is the long hose and vise grips--you risk sucking some brake fluid into the engine this way if you leave vacuum on it too long,but it wont hurt it any,it'll just make smoke,possibly foul a plug,but if you watch the fluid in the hose you can stop it from ever reaching the engine--takes quite a bit of fluid to fill that length of hose..
This method has worked to bleed stubborn clutch master and slave cylinders too....only bummer is it wont work on my diesel pickup--no vacuum on a diesel engine,and the vacuum pump on it is not suitable to use for this process ..
