Brake Caliper Brackets, 14 Bolt.....$45 for CK5
No offense taken I was just letting you know. So the front rotors off of a 75 3/4 ton truck will work. Would the rotors off my old 10B front work?
BTW do you have a part # for the 3/4 ton rotors and or caddy calipers
anyone else have caliper bolt to rotor clearence issues? Im installing mine as we speak and when i run the bolt through the caliper and bracket it hits the rotor. I did get 75 chev 3/4 ton 4x4 rotors. i will go take a couple pics to see if it tells you anything. But basicly everything looks lined up perfectly but the bolts.
i'll chek the websight to see if there is records kept or anything but im pretty damn sure i ordered the correct ones.
no the bleaders should allways point up. the air rises in the brake fluid.
Edit: just varified that i ordered the correct ones. I wonder if maybe these rotros are wrong? or miss boxed? i dont know...
oh yeah thats right i knew it was one of thoose ways.....
Looks like you were sent the shorty.....
I will get out the correct pair in the morning, the pair you have are 3/16" too short. They are made for 15" aluminum wheels and to use them you would have to turn down the rotor, I have the right ones and will send you a pair tommorrow. I am very sorry for the misstake. Find someone that has some very expensive aluminum wheels and give the others to him.
How is it that when you run out of something......
It seems to be the only thing anyone wants'?
We sold 27 pair in the week we had only the wrong size, it always happens.....
Dan, it's me again to bother you about the Dana 70 brackets. Do we have a time frame (just a ballpark) as to when they will be ready for sale?
Thanks again for your patience!
I wish we had them now......
My bender is making them again, he says he shipped them but i think they are sitting in some corner of his shipping department. Maybe worse, maybe his son in law got his hands on them and then something always happens. Whenever he touches anything something happens.
OK, here's the deal... I have calibers from G20 Van, and rotors from G30 Van that are turned down on lathe to fit on 14FF hubs. Will your brackets fit?
Why Van parts, they are much easier to find in here compared to K20 parts.
Just ordered a set and very excited. Thanks for the prior info Dan. I will let you know when they are on and rolling.:D
They should fit.......
The caliper has the same spread but we will take them back if neccessary, give me a call before you order them and we can be sure.
Just wondering about those turned discs, I didn't have any specs about them, so I just made them to fit on hubs. What's the overall thickness of the K20 disc? From hub to back of the disc.
OK Dan, I will stop bothering you about Dana 70 Brackets, ONLY if you will make me some for my Rockwell.......
