firefighterco2
Registered Member
Ok ill try to make this as short as possible. 87 k5 factory 10 bolt rear. Been having a grinding noise in the rear brakes since I bought it. Finally traced it down to the drum rubbing on the backing plate(I think that is the correct terminology). I have new shoes, all new springs, new wheel cylinders, the drums are both also new. I have been through 4 drums in the last 2 days trying to find one that didn't grind or wobble like the wheel is going to fall off? The guys at the parts store know me by name now.
Is there anything that could be causing this on my blazer? The backing plate doesn't look bent? When I switch sides with the drum the problem goes with it. The other drum is fine. Is there any way that I could have put the c clip that holds the axle in wrong when I replaced the bearings? is there anything else I'm missing???
Sorry for the long post and thanks for the help.
Jeremy
Jeremy
