Brake Job
I went disc. Should have stayed drum. The cady calipers were beyond me to get working. Kinda slow.
Cadillac calipers are easy to make work. Bleed them with the port straight up, hard to do with the normal mount, even in factory mode. They may require you to unbolt to get the air out. The parking paw has to be properly set for the caliper to work properly. The second requirement is to use the parking brake all the time. This is how the caliper is adjusted.
