MuzachMT
Registered Member
So,
I noticed I had a driver side brake light out, tried a bulb, no luck. Redid the ground under the housing, nothing. So I started playing with the wires in front of the rear bumper. Now the driver side brake light works, both blinkers work, flashers work, tail lights work, but NO pass. side brake light!!! There are trailer lights hooked up with one green wire coming off to the drivers side, which I disconnected in my messing around. Is this a complete circuit where as that trailer wire needs to go somewhere? Also the 4 prong plug back there is missing a tab on the female side (which I now know is supposed to be like that).
Also, drivers side blinker will not blink, just stays on, but flashes with flashers on. Will the blinker switch cause the brake light to not work?? And why did one side work, and not the other, now the opposite?
ahhh!
ahhh!
