brake lines d44 and 10bolt
[ QUOTE ]
will stock 10 bolt brake lines work on stock d44 brakes??
[/ QUOTE ]
Nope. Just get extened brake lines, you'll need them any way. /forums/images/graemlins/thumb.gif
They will work with 2 slight modifications, you have to ream out the brake line hose end that mounts to the caliper and you have to shorten the banjo bolt 1/8". 10bolt calipers are 10mm and D44 calipers are 7/16"
