4 wheel disc brakes on a Dana 60 front and FF14B. Biggest aftermarket master cylinder available?
Ready, and GO!
Ready, and GO!
Either or. Doing some research for multiple builds
Vacuum: '99 C3500
I was going to try this one, but there are two disk/drum and disk/disk.
the disk/disk is listed as 40MM, but has the correct port size routing (lines from primary to secondary) as a stock 1978 k5.
Meaning lines and fittings will go as standard no adapters, but the bore size is 1-1/2".
The disk/drum is 1.250 bore size, with the fittings reversed so it would take some line re-routing to get to go in.
I'm running vacuum- do you know which master cylinder you went with?
