Brake resivoir cannister for power brakes
454 blazer
bahrain
Hey guys,its been a while,need help!Is there any cars/Trucks that i could find in a scrap yard to pull a brake resivoir can , im running a big block with a rather large cam that is pulling all my vaccum from the intake making my braking rather interesting :eek1: i was just wondering wether there is something easy to find and install :dunno:
Thanks in advance guys :bow:
You might switch to hydroboost, wherein the brakes are boosted by hydraulic pressure from the power steering pump instead of vacuum. The 6.2 diesel trucks use this 'cuz, well, they have no vacuum :D
You can search on this, but basically you'd need the hydroboost unit (the booster), the power steering pump (or the can for it anyway), the three hoses, the brake pedal assembly, and replace the master cylinder as it's different.
Alternately, I have seen vacuum reservoirs, yes, but they're not common. Basically they're just a metal tank that's airtight, so you could use one from any sort of vehicle.
Mind you, if your motor isn't pulling much vacuum, a reservoir might not help much. It's like a battery in that it needs charging, see; if the problem is that your motor doesn't pull vacuum intermittently, then, yeah, the extra capacity would level it out, but if it's just low ... you need another solution.
-- A
Like dremu says, most folks in your situation go hydro. I'm not a huge fan of it, because if the engine stops, you have no boost. My folks had a lincoln town car that had it, and something went wrong. Don't know what it was, because the dealer finally found it and fixed it.
But, until they did, every so often you would pull up to a stop sign or light, hit the brakes and just have a hard pedal.
That would not have been all that bad, because you still had brakes, it just took a lot of effort to stop.
Bad part was, about halfway through the stop, sometimes the boost would suddenly kick in and you would lock up all four.
Of course, you have very little now......
Before you do a lot of remodeling, make sure the check valve is working in the vacuum line and your booster is working right.
I would find some level lonely road, wind it up some in low gear, then take your foot off the gas and let the engine compression slow it all the way down.
That should create maximum vacuum.
Do not use the brakes, just coast to a stop. Turn off the engine, let it sit for a minute or so, then hit the brakes.
You should have a fairly normal boosted pedal. Let it up, and hit them again.
You should get about two boosts with the engine off.
If the pedal is hard the first time, then you have either a bad check valve, booster, or the engine is not making any vacuum at all even under ideal conditions.
If you can order from summit racing or jegs they off vacuum resevoirs for about $45 + freight.
I have a fair size cam in my 454 and it's always worked well for me.
If you can order from summit racing or jegs they offer vacuum resevoirs for about $45 + freight.
might think about an electric or belt driven vacuum pump. ive used the belt drive i liked it
