Brakes Problem¡¡ Help Please!
Jaguargt
Guatemala
Hi guys, i have a 83 K5, 6.2, great truck, the problem is every time i hit the brakes, the truck pulls me to the driver side really bad, really bad, what should i check? thankx in advance.
Pass side caliper. It's probably not working. AFter that, there's a ew other things to check, but I'll leave that to the experts.
the rotor could be scored or the pads are gone on the side its pulling to. or bleed the caliper ont he side its not pu;;ing to
Could be several issues including but not limited to:
Stuck caliper (stays applied)
Frozen caliper (won't apply)
Worn out rubber line (bulging)
Bad rotor
Bad pads
Frozen caliper bolt/slide C10/D44
Stuck Caliper D60 (where it "slides" along the backing plate)
Oil/debris soaked pads.
Pinched hard line
Crap in Prop valve (not that likely, but.....)
